davidwort
fitting a non adjustable steering column (how-to)
I think the washer should be against the spring, can't find a close enough photo of mine at the moment, I think the polo column I had came with an all in one spline adapter and top collar which may be the difference, looks like a pressed steel round collar thing on yours.
I'm about to do this conversion myself. I've removed the corrado steering column and Ive found the correct used polo column. I take it from your write up davidwort the only brand new parts I need is a corrado ignition switch, a corrado steering lock and sheer bolts? Everything else should come with both the columns?
