yool74
Can not find the manufacturer
I have some damaged three piece wheel but can't find the manufacturer.
5 spok and 32 bolt
16 inch and width is 200mm
can you guys help me out here?
oh. and I found the sign of 'jw??' from middle piece and it is from Japan.
I also checked the gotti. I really hoped it was gotti but those guys said it is not theirs.
oh. and it is three piece just like gotti.
What company name would start with j??
If it has JWL or VIA stamped on the rim like this:-
JWL is a logo of the Japanese Ministry of Land, Infrastructure, and Transport that certifies that an alloy wheel has passed the safety standards, like the European "T
I can confirm that those wheels you have are 8x16" 5x114.3PCD WORK Equip 3-piece split-rims.............I know because I have a set too, see below:
Are you sure however that they are 32-bolt because they are usually always 36-bolt, like mine. They are pretty rare wheels now and no longer made. If you need anymore info then let me know,
Cheers
Wheel has only jwl mark on the middle.
It is 32 bolt and I cannot be sure about this but my bolt pattern is 5X120.65
but the wheel right above me looks extremly same as mine.
Can you tell me what's the name for it?
uh, I said the name of the wheel in the post above, WORK Equip 01's. :wave:
If you are sure the stud pattern is 5x120PCD then that is BMW fitment and rare in that fitment too.
I also used to have a set of WORK Equip 01's in BMW fitment but they were 8x17" all round, they ended up on my mate's e36 M3 and looked amazing.
