vagingit.co.uk 0 Posted December 13, 2008 how easy is it to remove and then re-fit a front wing, drivers side if it mankes any difference. my other halfs corrado could do with a new wing, but just wondered if its an easy swap as Ive found one the right colour. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted December 13, 2008 AFAIK, it's just bolts and then tonns of underseal which acts as a kind of glue. So, it'll be all the 10mm bolts down the side of the engine bay, then I think there's one underneath the sill, down at the bottom by the door. Oh, and the wiring for the wing indicator too! After that, I think the wing should pull off: depending on how much underseal was used, you may need to peel the wing off or use a bit of force, but if you're replacing it anyways then it shouldn't be much of a problem. Jon. Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted December 13, 2008 gently use a hairdryer at the bottom of wing by the door sill. This helps the sticky stuff become more pliable. Quote Share this post Link to post Share on other sites
keithabc216v 0 Posted December 13, 2008 hope to see you sunday ? ill talk to you about it then Quote Share this post Link to post Share on other sites
