mike1955c
POWER STEERING PIPES
Hi out there Got a big problem and hope someone can help. My almost perfect 1990 180016v carrado burst a power steering pipe and according to the great vw agent in my town , they are now obsolete parts as are door handles. Car now lying off road till i find replacement pipes to go from the rack - reservoir and also from rack - pump. I was told in the past that the pipes im speaking about were made by a third party company and not vw which would be good if i could find out who. anyway , can anybody help??? i beleive they used the same pipes on the mark 3 golf and early passats look forward to any input cheers
i'm looking into getting a specialist firm, like Hyflex or Pirtec to make me up a hose. Might be worth speaking to someone like that.
i'm getting new hoses put together for different routing, cheap as chips. Although the standard routing includes that metal bit for cooling.
The cooling pipe is on the return side, and unpressurised so it's easier to cater for.
I make these very hoses...check my website for contact details, prices are £70 for the high pressure hose and £50 for the low pressure hose, or £110 for the pair
I'm not in work until the 5th jan, and my electroplating company are closed as well, but if you're desperate I can make you a set this week and paint them instead of having them plated
Pirtek, in my experience, aren't much use...I've sorted out quite a few messes caused by their "handiwork"...they like to use compression fittings because they can't do the correct flares for the hose ends and in one case, the poor guy had sent his hose off to pirtek, who cut it into 4 pieces before declaring that they couldn't do anything with it...nice!
My website is http://www.powersteeringstore.co.uk
cheers Rich
Seeing as the helpful part of my last post was deleted, call me on 07917 697262...
It all came back after some forum issues.
How much would you want for a reconditioned rack, for a VR6?
