marf497 0 Posted January 3, 2009 Hi guys wondering if anyone can help me with this small problem. My rev counter at idle reads about 500rpm but the car is definetley idling a lot highter (sounds normal) when I drive my rev counter always reads lower than they should be this has been like this since I got my car about a year ago. Any ideas would be apreciated I don't know if the clocks are out of a different corrado or even if that would cause the rev counter to always read low. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 3, 2009 What does the speedo and rev counter read up to? Quote Share this post Link to post Share on other sites
waynos 0 Posted January 3, 2009 sounds like sombody has had your clocks apart at one point. If you strip them apart you can take the needle off and put it back on in a higher position. On the g60s i know there is a way of getting the revs to read on digital clock so you may be able to do the same on your and adjust it accordingly Quote Share this post Link to post Share on other sites
marf497 0 Posted January 3, 2009 my speedo goes upto 160mph and rev counter is 6000 then red line at 6500 and my fuel gauge is 15 gallons. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 3, 2009 You've got VR clocks for some reason dude - Valvers should read up to 8k rpm Quote Share this post Link to post Share on other sites
marf497 0 Posted January 3, 2009 cheers might look at changing them in the future. Quote Share this post Link to post Share on other sites
junkie 0 Posted January 3, 2009 Is that all valvers, i was looking to change to the 8k cluster but thought it was on the early set up? Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted January 4, 2009 You've got VR clocks for some reason dude - Valvers should read up to 8k rpm And that explains the low rpm as it's looking for 6 impulses rather than 4.... so will be 2/3's of actual revs... Quote Share this post Link to post Share on other sites
marf497 0 Posted January 4, 2009 Cheers can I put any clocks from a 16v or would it need to be a 2l 9a engine ?? Quote Share this post Link to post Share on other sites
ben_wooduk 0 Posted January 4, 2009 my speedo goes upto 160mph and rev counter is 6000 then red line at 6500 and my fuel gauge is 15 gallons. mate, i have a 9A and my clocks are exactly the same as yours. and mine are defo valver clocks Quote Share this post Link to post Share on other sites
easypops 8 Posted January 4, 2009 my speedo goes upto 160mph and rev counter is 6000 then red line at 6500 and my fuel gauge is 15 gallons. Mine is exactly the same.......2.0 16v 1993..... :shrug: Quote Share this post Link to post Share on other sites
marf497 0 Posted February 5, 2009 Got the other problems with my car sorted body work damage repaired like a new car now and my no starting cutting out issues sorted so now back to my rev counter anyone know if I can do any adjustments using Vag-com to get it reading correct Cheers. Quote Share this post Link to post Share on other sites
marf497 0 Posted April 22, 2009 Eventually got round to changing my clocks and my rev counter now works properly. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted April 23, 2009 You've got VR clocks for some reason dude - Valvers should read up to 8k rpm Yup my "Late" (92) Valver's this... 15 gal, 160mph, 8000rpm, redline's about 7k Quote Share this post Link to post Share on other sites
