__Andy__ 0 Posted January 21, 2009 just changed over my steering wheel and now the horn doesnt work, it had a momo on it before and ive fitted anothe momo, put the connections on exactly as it was when i took it off and now it doesnt work!! Any advice would be greatly appreciated.. Regards, Andy Quote Share this post Link to post Share on other sites
Flexso 0 Posted January 21, 2009 Hello Andy, If you havent touched the boss it can only be to things really. I think it will either be that its not earthed well enough or the horn isnt working. Mike Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 21, 2009 remove the horn push and short the earth wire to the metal of the wheel/boss, just to make sure it's not simply a poor connection to earth for the horn push itself, if that still doesn't work, check fuses as the next step. Quote Share this post Link to post Share on other sites
__Andy__ 0 Posted January 21, 2009 cheers for the quick response, will check it out 2moro.. Quote Share this post Link to post Share on other sites
n3p 3 Posted January 21, 2009 Behind the grille I found a high/low horn. If you only have one connected, try the other one :norty: Quote Share this post Link to post Share on other sites
__Andy__ 0 Posted January 21, 2009 Behind the grille I found a high/low horn. If you only have one connected, try the other one :norty: sweet, will check this aswell.. Quote Share this post Link to post Share on other sites
