__Andy__
Help!! Horn not working!
just changed over my steering wheel and now the horn doesnt work, it had a momo on it before and ive fitted anothe momo, put the connections on exactly as it was when i took it off and now it doesnt work!! Any advice would be greatly appreciated..
Regards,
Andy
Hello Andy,
If you havent touched the boss it can only be to things really. I think it will either be that its not earthed well enough or the horn isnt working.
Mike
remove the horn push and short the earth wire to the metal of the wheel/boss, just to make sure it's not simply a poor connection to earth for the horn push itself, if that still doesn't work, check fuses as the next step.
Behind the grille I found a high/low horn. If you only have one connected, try the other one :norty:
sweet, will check this aswell..
