steve@flexi
Sunroof!
It would be far cheaper and easier to repair your existing sunroof, welding the hole up is a bit extreme, plus you will need to consider how to trim the inside of it.
Repair it and you'll also benefit from having a sunroof, which is nice when the weather is good. 8)
Hmm weld/fill/smooth/paint... :shock:
or replace a couple cables/clips (or the whole unit) 2-3hrs work...
Have a look at the Wiki, there's a really good guide there... :grin:
Would be quite a bit of work. It would be very hard to weld a panel in there without distorting the metal.Then obviously your whole roof would need filling and painting. After that you would have to source a non-sunroof headlining which wont be easy. Id say take some time out and repairthe sunroof or take the opportunity to upgrade to a passat moonroof
