mort1414
brake pistons
try using a foot pump conected to the loosened bleed nipple if its off the car block the feed using an old flex with a clamp on
Rob
yh there off the car will an electric pump do it?
i've only ever used a foot pump , more control but try it you never know
Rob
so if i clamp the hose end up lossen nipple and fit a halfords foot pump to nipple and pump piston should come out ok cheers for all the help thats 2moro morning sorted
