Kempy 0 Posted January 31, 2009 Hello I started delocking the boot today. So far so good, I've removed the barrell and filled in the hole. then I mounted up the solenoid. Next is the wiring I thought I's use the rear wiper power leads. There is a yellow and black, Brown, and green and yellow. the solenoid has + and - spades, so I've wired up one to earth on the body and tried the yellow and black on the other, this works but only once and when I turn on the ignition. I've also blown fuse 4 a bunch of times The idea is for it to work when I push the rear wiper stalk Any help would be helpful cheers Quote Share this post Link to post Share on other sites
Chris 0 Posted January 31, 2009 good idea untill you accidently knock the stalk a few times whilst driving :D Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 31, 2009 Untill recently I didnt even know how to work the rear wiper, I had a corrado for about 3 years :cuckoo: did you delock your boot? Quote Share this post Link to post Share on other sites
Chris 0 Posted January 31, 2009 Untill recently I didnt even know how to work the rear wiper, I had a corrado for about 3 years :cuckoo: did you delock your boot? lol, you just no that youll end up knocking it at some point. i havent yet but i think i will after ive finished the engine. i think ill be tucking a switch away inside the dash tray Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 31, 2009 I got a switch with my kit which could be run straight off the battery. I'm lazy and thought It would run easy of the wiper power :brickwall: The main reason I'm doing this is because I got 3 keys and I gotta take the keys out the ignition to open the boot if a passenger wants to get something from the boot :mad2: Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 31, 2009 anybody a wiring wizz? Quote Share this post Link to post Share on other sites
