brian g60 corrado 0 Posted December 21, 2003 hi all have been trying to get co set right,got it running nice last night went for a spin and was going very well ,then started running s**t. could it be coil,distributer or knock sensor as i feel it could be one of these three .i have heared that the hall sensors can be a problem any ideas.cheers Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 21, 2003 could be anything...what happend,why is it sh*t..try and describe the prob Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 22, 2003 hi steveo problem started only when started from cold would splutter for a while then cleared.now problem has started when warmed up and driving along. parts changed as follows. metal head gasket/blue coolant sensor/o2 sensor/s,charger/chip and pully/ignitionkey switch. now the only parts i havent changed yet are.distributer/coil/knock sensor. i have heared that hall sensors inside distributers are prone too failing,also the knock sensors can fail. have checked all earths allseem ok,have set co pot to 550 ohms and also tried other settings had car running nice ,drove for a while then started running rough possibly rich any ideas on a possible cure much thanks :? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 22, 2003 hello there , have you checked the timing ?? what chip are you running ? if you want to give me a call.. Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 22, 2003 hi darren i have a german chip from thomas,im sure the timings ok . may have to ask you to take a look at it some time ,also do you have the plug in computers to test for faults ect.what would you charge for ecu check and set up. thanks for reply. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 22, 2003 humm you say you have changed the lambda / co and checked all the earths from the ecu .. ?? is your 1mtr hose from the back of the throttle body to the ecu ok ? Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 22, 2003 sorry forgot to mention im sure that this fault was there before chip swap .just seems to have got worse. Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 22, 2003 yes the hose is ok Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 22, 2003 have you check all the vac hoses ? have you removed the carbon canister ? have you balnkedall the outlets if so ? is you isv working ? does it get worse wen warm ? sorry for the questions just think of possibilatys :lol: Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 23, 2003 have checked all hoses all look ok,still have carbon canister,havent tried blocking any pipes yet which ones toblock Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 23, 2003 have checked all hoses all look ok,still have carbon canister,havent tried blocking any pipes yet which ones toblock no no you only blank of points if you have removed carbon canister... Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 23, 2003 from cold. idle speed was all over the place would also rise to about 3k sometimes. then would settle,then drive and idle ok,even before i fitted chip and 68mm pully. now it drives ok, but intermittantly runs poor spluttering with loss of power. the other night i set co to 2.5% in tuning mode.took for a drive and ran realy well , the computer showed 40-50mpg .i could not belive it.then started spluttering and running very rich.adjusted co back to 550ohms,then drove home . like i say it was realy flying then lost power and rich.could this be distibuter or knock senser.thanks for helping out with fault. :? Quote Share this post Link to post Share on other sites
