Kempy
rear break lights
corrados 2 or 1? I've fitted led amber indicators some reason only the one break light flashes, cant figure out why. the filments are fine in the bulbs :shrug: :shrug:
Put the old bulb back in and see if it works then!!!!!!
Do any of the lights work in the side with the problem with the new bulb/LED
If so try the follwoing
1. connector not quite home into the socket???
2. Blown new LED
3. Damaged cables when removing loom to the rear light chack them
4. Damaged PCB that bulb fits.
5
I had to fit a resistor so that the LED would flash slower, the indicator now flashes correct and the red light comes on but it dont flash when I break. Probably worth getting a new bulb. I have checked it with 2 different ones already
