Stingray
Battery Drain
Hi hope someone can help, i have a 1.1 amp battery drain on my corrado g60 but only when it is locked up. Battery drain is 0.050 when key is out of igniton and door is shut, but after i lock the car with the key (no alarm fitted) the battery drain settles down to 1.1 amp which is way to high.
Any help would be appriciated, cheers Jaime.
Sounds like a central locking fault maybe? Do you hear the locking pump running still?
i just sorted mine from doing this.
The locks were a bit stiff so the central locking couldn't fully shut them and the pump kept buzzing away trying to lock it fully.
Greased up all the lock mech's n its sorted.
