delfinis38 1 Posted March 20, 2009 Sorry mod's not sure where this should go as it's non VAG. the previous owner of my daily driver has left me with one damaged locking wheel nut to remove Grrrrrr. It's one of those rather Cr@p pattern combinations that have been nicely rounded off. Any advice on the removal.... just done a bit off googling and found you can buy special lock nut removal tools but i can't see how they will actually work. Ta... and ave a good weekend..... Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted March 20, 2009 I'd be tempted to contact a local tyre centre and they must have to contend with this all the time Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 20, 2009 i;ve seen many people just hammer a socket onto them Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 20, 2009 Does the locking wheel nut tool look like a socket with a reverse thread in it? I bought some of these to get the mcguard locking nuts off, didnt have much luck with them tbh. If you wish to give them a try, let me know and ill post you them to try. The best bet i'd say though is what 3CM said ^^^ Quote Share this post Link to post Share on other sites
Henny 0 Posted March 20, 2009 i;ve seen many people just hammer a socket onto them used this method a few times... got quite a few knackered 19mm sockets now :? :lol: Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted March 20, 2009 Worst case is to get a socket welded onto it! I've PM'd you a suggestion though! :wave: Quote Share this post Link to post Share on other sites
KADVR6 0 Posted March 20, 2009 i used one of these on a full set ages ago http://cgi.ebay.co.uk/IRWIN-TOOLS-5p-BO ... 8001r25772 they worked a treat :) Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 20, 2009 Worst case is to get a socket welded onto it! I've PM'd you a suggestion though! Thanks for both your Pm's.... I suppose the easier solution would be just to use the Rado more :lol: ... she passed her MOT this week too. Now that's a proper car..... I'm considering making some sort of jig up to stop the socket jumping.... but i'm not intending to spend long at it before i give in :brickwall: Quote Share this post Link to post Share on other sites
Slimg60 0 Posted March 20, 2009 I've got a set of removal tool, it's basically a some big sockets with reversed thread tapered on the inside, so as to tighten it it actually locks then undoes the stud. Picked these up fairly cheap from GSF I think. Or the hammer and socket method usually works :D Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 20, 2009 either reversed thread sockets, beat a standard socket onto the broken locking nut OR as i have had done a couple of times get a garage/engineers to weld a bolt onto the locking nut and then undo that. Quote Share this post Link to post Share on other sites
