Josh Waddi 0 Posted March 23, 2009 Hi People didnt get a reply originally so i will try and re-word what im looking for i understand the size fitment with regards to the actual " size of the alloy. But the offset?? and diameter or the bolt circle???? and the centrebore???? all throw me off and due to previous bad buys i dont trust sellers when they say they will fit. i needed to know what size or range of sizes which will fit a early 4 stud C? with standard brakes. Cheers Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted April 14, 2009 Paragraph re-phrased Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 14, 2009 4 x 100 and ET35 seems to ring a bell, original alloys are narrow 6.5J (inch wide rim?) though, most 15's at least seem to be 7J? Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted April 14, 2009 Early 4 stud are: 4x100 PCD, Offset ET35, Centre Bore 57.1mm As long as you stick loosly to the offset (+/- 5mm ish) you shouldn't have problems, unless you're going for 9" wide rims, then some arch rolling/pulling may be required. If an aftermarket alloy has a larger centre bore then spigot rings would need to be used to reduce the wheel's bore down to 57.1mm HTH Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted April 14, 2009 Cheers you two. i can go hunting with knowledge now Quote Share this post Link to post Share on other sites
