Josh Waddi
Which Size Fits???(Ammended Title)
Hi People
didnt get a reply originally so i will try and re-word what im looking for
i understand the size fitment with regards to the actual " size of the alloy. But the offset?? and diameter or the bolt circle???? and the centrebore???? all throw me off and due to previous bad buys i dont trust sellers when they say they will fit.
i needed to know what size or range of sizes which will fit a early 4 stud C? with standard brakes.
4 x 100
and ET35 seems to ring a bell, original alloys are narrow 6.5J (inch wide rim?) though, most 15's at least seem to be 7J?
Early 4 stud are: 4x100 PCD, Offset ET35, Centre Bore 57.1mm
As long as you stick loosly to the offset (+/- 5mm ish) you shouldn't have problems, unless you're going for 9" wide rims, then some arch rolling/pulling may be required.
If an aftermarket alloy has a larger centre bore then spigot rings would need to be used to reduce the wheel's bore down to 57.1mm
HTH
