vagingit.co.uk
changing the bonnet
the bonnet you've bought/acquired, is it to be re-sprayed? All body shops should know how to fit it perfectly, should you find that you can't quite get it perfectly aligned.
I found it pretty easy... take your time with the connections for the heated washers and the water pipe when you're taking it apart as they tend to go brittle...
Make sure that you've got at least 2 people to help... 2 of you will be needed to hold the bonnet in place while the third will just be needed to put the bolts in.... you can do it with just two of you, but it's not as easy....
Just take your time, and don't just drop the bonnet expecting it to have lined up perfectly first time! There's quite a bit of adjustment you can get out of the hinge mounts onto the bonnet...
Oh, and remove the grill before you even consider doing this, so if you don't quite get the lineup correct and find that it's closed but the catch is too far forwards to be released by the cable, then you can get your hand in and release it manually... ;) :oops: :roll:
