stevej 0 Posted April 5, 2009 Hi did this conversion on my previous C worked a treat. I have removed a single wiper conversion from my recently purchased C. i had a spare wiper linkage set up / motor form my old valver so i just slotted this into place & put on the lupo wiper arms & blades (part no.s as per the wiki). Problem is that niether blades will sit flush against the windscreen throught their cycle and large parts of the screen dont get cleaned. Its like the spring in the arm isn't strong enough to hold the arm against the windscreen with enough pressure to keep the blade flat against the screen. anyone has the same issues / solutions :scratch: cheers Quote Share this post Link to post Share on other sites
paddy26 3 Posted April 5, 2009 I read somewhere that some of the screens are not fully convex and have "flat spots" in them.if you do a search you might find out which brand this is. I had the same problem when I installed lupo wipers so I just put a bit of a bend on the wiper arms which worked as a temporary fix. I don't like it as now the wiper arm doesn't sit low and flush to the screen. I'm waiting until I respray the car and then I'm replacing my screen. It had a chip it in from when I bought it and now it has cracked. Paddy Quote Share this post Link to post Share on other sites
stevej 0 Posted April 8, 2009 Cheers Paddy, anyone any other thoughts cheers Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted April 8, 2009 My passenger one did this (I used OE VW Lupo wipers) and I bent the arm very sligthly and it did the trick. Quote Share this post Link to post Share on other sites
