awigman
In car DAB
Is anyone running DAB in their car? I am trying to find the best sort of aeriel to use.... exterior window mount...windscreen mount or just a splitter using the original aeriel. Has anyone had any experiance with any of these
Thanks
Yeah I've got a Sony DAB unit in my car with a £30 stick on windscreen aeriel. It's quite sh1te, but I don't know if that is DAB or my set up as I've never been in another car with DAB. Basically I get reception in cities, but nowhere else. :(
I believe a proper external aerial is meant to be best, I'm currently using an internal aerial and only get the BBC assembly unless on a motorway.
Sadly using the Corrado aerial will prevent you from using a splitter due to the fact it is amplified, apparently the splitters only works on non amplified aerials. Worth keeping an eye out for the dual feed aerials which look like the standard Corrado unit but offer feeds for both analogue and digital.
