steveo29
a/f gauge..wont cycle at idle...what now
my a/f gauge wont cycle at idle...ive tried another gauge thats spare and it does the same thing....the car starts and drives normal and the a/f cycles when cruising....its on a G60
The o2 sensor generates 0.45V when cold, which falls in the 'OK' range but after the preheat has finished (after approx 2 mins) it should, as you say, fluctuate from 0.1 to 0.8V.
Strange it's fluctuating when driving and not at idle.
Is the guage showing 'Stoich' at wide open throttle?
Dunno to be honest.....maybe the lambda probe is on it's way out? When they stick at 0.45V at idle, that's usually a good sign.
K
Mine does this steve.
i noticed it on my last chip. when i leaned it out it would cycle. ive been really lazy and not done any more fine tuning so mines the same. itll sit at middle to rich on idle and cycle when moving and holding around 10 vac. im gonna lean out a bit more as im still rich and im pretty sure this will sort the problem.
tell tales like plug colour and exhaust give it away.
i got MOT in a few weeks so im gonna try and get the wideband done this week to sort it.
