dragon green
MINI WHEELS ON A CORRADO ?
They've got a look of the BBS LM about them.. they look pretty decent, definately!
The centre bore is too small if I remember correctly, you can have it machined to open it out if I remember correctly.
Centrebore on the Mini wheel is 56.1mm as opposed to 57.1mm on the Corrado so it's either machining or a bit of work with a half round file to get them to fit. Off-set is not quite right either so you will need spacers.
From memory they're BBS too!
Will need splitting and lips polished again (that's laquer lift/ corrosion in the pics)... any 1/2 decent engineering firm will open the centrebores out.
