KyleSteger
Head Light Removal
Anyone know how to remove the whole headlight assembly, or even just the glass? I Know the top two screws come out but I'm guessing something else it holding it in.
There's a hole in the slam panel and a 3rd screw down there, holds the bottom of the light on. if you look down from the top you should see it.
have to take your grill off to...
No you don't need to normally. Headlights will come off with the standard grille still in place.
