Pat_McCrotch
Central Locking lazy on drivers side?
Bit of an odd one this. I've done a quick search but nothing obvious comes up.
Basically; every 1 in 2 attempts to unlock the car from the drivers side will result in only the drivers door unlocking and not the other door/boot unlocking. If you unlock the car slowly it the whole car will unlock fine. However do it a little quicker and it's as if the mechanism can't keep up with what you are doing :scratch:
The Passenger side lock is absolutely perfect and it doesn't matter how fast you unlock it, it always works first time.
Not exactly a major problem but frustrating all the same, any ideas?
do you mean the passenger lock opens the others fine?
If only the lock you were operating with a key works I'd say it was a vacuum leak, perhaps you have a dodgy switch/wiring on the drivers side handle or loom, possibly at the door hinge area where the loom flexes?
