swisher837
Can't understand MFA readings
I just purchased a 91 corrado g60 & i'm slowly learning the mfa....does anyone have the "normal range" numbers for the readings.....I'm getting a 1680 for the #1 of MFA 2 & i have no idea what that means......please help!
Your 'user manual' will explain all.... each press of the button on the end of the stalk will change it to a different readout. slide the MFA 1/2 switch as far as it'll go either way to clear any stored data for that MFA.
Been a while but MFA1 is trip data and MFA2 is cumulative IIRC so 1680 is probably miles travelled since it was last reset (described above).
