lockdown 0 Posted June 28, 2009 Could find much info with the search function. Since I've owned the 'rado the MFA has never displayed the oil temp. How do I go about sorting this? Thought I would get all the little things sorted while I'm waiting for parts :D Thanks Quote Share this post Link to post Share on other sites
nocrap 0 Posted June 29, 2009 Doesn't give you the option or displays nothing when you go to that setting? if it's not giving a readout i'd assume that there is some sore or cabling fault or the sensor has completely had it. Check for unplugged wires first Quote Share this post Link to post Share on other sites
lockdown 0 Posted June 29, 2009 Its just reads a few dashes Quote Share this post Link to post Share on other sites
nocrap 0 Posted June 29, 2009 As above then, check the wiring. possibly replace the sensor Which engine is it? Quote Share this post Link to post Share on other sites
lockdown 0 Posted June 29, 2009 Kr lump mate. Where is the oil temp sensor found? Quote Share this post Link to post Share on other sites
nocrap 0 Posted June 29, 2009 urmmmmm....... can't remember of the top of my head! I know there are a few on the right side but i think they're all for coolant, something makes me think it's on the back! I'm sure someone else'll confirm Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 29, 2009 Top of Oil filter housing! Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 29, 2009 Top of Oil filter housing! back of the head just round from the dizzy! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 29, 2009 :) Sorry... what's on top of the filter housing then on a valver? nothing I assume? Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 29, 2009 Oil pressure? yep the two oil pressure switches on a KR 1.8 and the two switches plus a third plugged drilling on a 9A 2L, handy if you want to run a separate VDO oil temperature gauge too as you can fit another temp sensor there. Quote Share this post Link to post Share on other sites
lockdown 0 Posted June 29, 2009 thanks chaps! Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 29, 2009 just a thought, a loose, corroded or missing earth strap from the corner of the head to the ignition coil can screw the temp reading on a 16v Quote Share this post Link to post Share on other sites
