TimDoc
Vagcom codes
Anyone shed any light on these fault codes I just picked up on my Corrado VR6?? Anything to worry about?
Address 01 -------------------------------------------------------
Controller: 021 906 258 AG
Component: MOTOR PMC 1
Coding: 0261203109
Shop #: 1267357531
2 Faults Found:
00515 - Camshaft Position (Hall) Sensor (G40)
30-00 - Open or Short to B+
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
Readiness: N/A
thanks
Tim
If the engine is ignition on, engine stopped, ignore 00513. 00515 may be genuine and your engine is in "get you home mode". Reset the codes and if 00515 re-appears, change the cam position sensor. But...... if the top end of the engine has been recently been done suspect the cam drive chains have been put back incorrectly. If so a top end job, check all valve / cam/ chain alignment first.
