PROVR6 0 Posted July 26, 2009 Im thinking of getting some of these to replace the original vw door speakers. Does anyone have experience of them? Will they be a noticeable improvement over the factory ones? Will they fit ok (read some 5.25inch speakers are slightly different) or should I just stick with what Ive got :shrug: I gather the best benefits come from bigger speakers which need doorpods, but I want to keep the doorcards standard. Quote Share this post Link to post Share on other sites
junkie 0 Posted July 27, 2009 Rainbow are highly regarded as good speakers and they will definately be a huge improvement over standard, the improvements you get by going to a larger diameter speaker is more mid bass, but by keeping the standard sizes you will get alot more clarity and definition, both should give some good increases in volume. Quote Share this post Link to post Share on other sites
Rams 0 Posted January 12, 2012 I'm just about to wire mine in today hopefully, they are the same make but different model. I've actually modified speaker pods available in 6.5 inch if your interested? Can send you a picture later on. One is covered and the other isn't. But remade from original pods so they don't stick out so much like the audioscope. For later model C with elec window switches in pods. New replacement speakers will be a definate improvement but if you can go larger, amped up will sound even better and clearer. Most say, good set of components, woofer and job done. Quote Share this post Link to post Share on other sites
