_leon_
rust protection wax
Whats the wax protection that VAG use/used to protect panels and openings through the floor from moisture/rust? I'm removing a few areas and want to rewax the areas. Is iron primer suitable to use as a base coat? Sure I've used that before - but unsure if I should use another primer instead. Any advice appreciated
you want the underbody wax in a rattle can from VW dealers, yellow stinky stuff that sets hard, not the engine bay clear wax, it's a tall thin white can with a slot in the side of the cap that has a long application tube with built in nozzle for those hard to reach places :)
for underbody areas clean back to bare metal and then use a very thin coat of acid etch primer followed by VW underbody rubberised sealant brushed on. Then paint over the top of that.
cheers for the advice - i'd also be doing the interior too - so would any other product be best suited?
