fla
removing pedal box
I've removed all the bolts from the pedal box (actually Zak did that!), plus ther was another hidden high up in the dash. still cant get the pedal box out and it seems as though the brake servo master cylinder is holding it back. Is there any way of removing that collar from the front of the master cylinder (cabin side)?
You've got to pull the master cylinder/servo forward into the engine bay so that the studs don't poke into the cabin, and the end of the piston is clear of the hole in the pedal box.
cheers Toady, this was winding me up this afternoon no end. Two days with the kids and then back to sorting this out on friday hopefully looking to tie it up over the weekend...
