culshaw
Engine block flange connector to heater matrix (2.0 16v)
Hi,
An oval ring has gone on my flange (vw original part no. 051121145d), just rang up VW and its £45 does anyone know what the part is actually called so i can try and find it on gsfparts, or if anyone has a spare one on here???
to help here is a picture! :) (says no stock on vw spares either)
Thanks
Ian
yep, gsf do them, around 7 or 8 quid IIRC, they also do the front one, which will probably be in a similar condition if you haven't changed it already, they usually come with the seal.
If you visit a branch or call they should be able to match the VW numbers below.
the side plastic flange is 027 121 145B and the seal is N 902 954 01
front is 027 121 133E and seal 027 121 139A
They are not £45 from VW - more like a fiver!
Thats what i was thinking as i bought one a while ago.......never got round to fitting it though, but gave it to the new owner when i sold it.....cant remember the exact cost but it was nothing like £45
bloke at vw might have presumed the wrong part or thought i wanted the pipe shoving into the flange..... :wave:
