Jim Bowen 1 Posted August 25, 2009 if i just do the clutch for now is there much else worth doing while i'm there (ignoring any engine internals/chains) i'm thinking -main water pump -engine/gearbox mounts -clutch and almost tempted to remove aircon, or get it working Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 25, 2009 is it best to get all the bits from VW Dealers? Quote Share this post Link to post Share on other sites
fla 9 Posted August 26, 2009 get the aircon working 3corsa - if you have leather its vital when it gets hot! Chains upper & lower, guides (there are two), chein tensioner (might still be ok), rocker cover gasket, exhaust gasket, inlet manifold gasket, get some RTV silicone for the gearcase side covers and rocker cover (i didnt apply any rtv to the rocker cover gasket and it leaks a little bit) Good luck, its not actually too hard. Also, use the guide in teh Wiki - i've got some pics that i can send you if that helps, plus i have some in my thread called 'tapping noise' Quote Share this post Link to post Share on other sites
