Wastegate86
colour coded door handles
there is something on this in the wiki, what do you mean aftermarket?
ps white corrados rule! LOL
ha ha you knows it! :grin:
have seen people fit flush audi handles
recon the the originals sprayed look good enough to me tho :norty:
Non Corrado handles can look ok but they're a LOT more work obviously compared with the simple route of spraying your existing handles.
You could de-lock by using Passat handles.
Either way, just follow the usual method for spraying (the guides for tinting rear lights probably applies here) ... lots of sanding/keying and making sure the area to be sprayed is flat and clean. Spray and rub back and spray again.
Mine are looking tired now but they lasted a good 5 years of looking great before needed some new paint.
with the handles being used quite often, do you do anything different than if you were painting a panel or something? to stop them quickly looking bad
Didn't do anything special with mine - just a couple of coats and lacquer. The key is in the prep. However, I seem to remember my prep involving about 3 litres of vodka redbull though so not sure if that helped or not. Give it a whirl anyway :grin:
Im going through loads of ABP from TPS, is there a place I can get larger cans? Rattle cans I mean
Mine came colour coded from the factory. But then my car is black. :grin:
alrite no one like a show off lol
cheers for the advise VR6
just got to see how easy the handles come off now :?
Apologies. :wave:
very easy, just one screw
if someone hasnt cable tied the wire going into it so tight you cant move it, like mine was :(
I'm completely useless at knowing if something is opposite thread....I've ruined a few bolts not knowing
