Wastegate86 0 Posted August 30, 2009 just wondering the best way to acheive this?? just spay the original ones, or replace them for aftermarket? :shrug: Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 30, 2009 there is something on this in the wiki, what do you mean aftermarket? Quote Share this post Link to post Share on other sites
STU175 0 Posted August 30, 2009 just had mine sprayed when han car done so not sure how it was done but should look like this http://the-corrado.net/.archive/forum/viewtopic.php?f=11&t=66097 not the best pics but gives you an idea :D ps white corrados rule! LOL Quote Share this post Link to post Share on other sites
Wastegate86 0 Posted August 30, 2009 stuartscales said: ps white corrados rule! LOL ha ha you knows it! :grin: have seen people fit flush audi handles recon the the originals sprayed look good enough to me tho :norty: Quote Share this post Link to post Share on other sites
VR6 0 Posted August 31, 2009 Non Corrado handles can look ok but they're a LOT more work obviously compared with the simple route of spraying your existing handles. You could de-lock by using Passat handles. Either way, just follow the usual method for spraying (the guides for tinting rear lights probably applies here) ... lots of sanding/keying and making sure the area to be sprayed is flat and clean. Spray and rub back and spray again. Mine are looking tired now but they lasted a good 5 years of looking great before needed some new paint. Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 31, 2009 VR6 said: Non Corrado handles can look ok but they're a LOT more work obviously compared with the simple route of spraying your existing handles. You could de-lock by using Passat handles. Either way, just follow the usual method for spraying (the guides for tinting rear lights probably applies here) ... lots of sanding/keying and making sure the area to be sprayed is flat and clean. Spray and rub back and spray again. Mine are looking tired now but they lasted a good 5 years of looking great before needed some new paint. with the handles being used quite often, do you do anything different than if you were painting a panel or something? to stop them quickly looking bad Quote Share this post Link to post Share on other sites
VR6 0 Posted August 31, 2009 Didn't do anything special with mine - just a couple of coats and lacquer. The key is in the prep. However, I seem to remember my prep involving about 3 litres of vodka redbull though so not sure if that helped or not. Give it a whirl anyway :grin: Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 31, 2009 Im going through loads of ABP from TPS, is there a place I can get larger cans? Rattle cans I mean Quote Share this post Link to post Share on other sites
nedssx 0 Posted August 31, 2009 Mine came colour coded from the factory. But then my car is black. :grin: Quote Share this post Link to post Share on other sites
Wastegate86 0 Posted August 31, 2009 nedssx said: Mine came colour coded from the factory. But then my car is black. :grin: alrite no one like a show off lol cheers for the advise VR6 just got to see how easy the handles come off now :? Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 31, 2009 very easy, just one screw Quote Share this post Link to post Share on other sites
nedssx 0 Posted August 31, 2009 Wastegate86 said: nedssx said: Mine came colour coded from the factory. But then my car is black. :grin: alrite no one like a show off lol cheers for the advise VR6 just got to see how easy the handles come off now :? Apologies. :wave: Quote Share this post Link to post Share on other sites
STU175 0 Posted August 31, 2009 Quote very easy, just one screw if someone hasnt cable tied the wire going into it so tight you cant move it, like mine was :( Quote Share this post Link to post Share on other sites
Wullie 1 Posted August 31, 2009 And remember the left hand thread on the securing screw. Quote Share this post Link to post Share on other sites
Wastegate86 0 Posted August 31, 2009 think this link should be usefull http://www.corrado-club.com/faq/techtips_search_results.cfm?FAQ_Search=door+handle Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 31, 2009 I'm completely useless at knowing if something is opposite thread....I've ruined a few bolts not knowing Quote Share this post Link to post Share on other sites
