Abdul
Brake lights/side lights are confused!
Hi guys, changed my brake light bulbs a few days ago (standard replacement bulbs) and have since noticed that my sidelights come on if i hit the brakes aswell!!
Any clues as to what could be causing the problem? Im hoping its not a short in the wiring.
Cheers,
Abdul
You put the bulbs in the wrong way round. The rear brake/sidelight bulbs are supposed to be keyed to only go in one way, but if you're a little ham fisted (like me) you can inadvertently force them in 180 degrees out.
Dr Mat, what do u mean the wrong way round? Ill have a fiddle with them tommorow and see what happens lol.
Are you sure there the right bulbs? Sounds like you've fitted bulbs with a single element in them rather than the 2 elements needed?
2 elements? Can someone put up a link to the bulbs i need so i can just buy em online? lol.. Im not going to lie, i think its quite cool when the sidelights flash with the brakes but i dont want any electrical probs because of it so its probably best that i fix it!
Anyone tried those LED bulbs?
Thanks,
Abdul
I did this once and it was wrong bulbs (single filament instead of double). Just pop into Halfords- they always have a bulb application guide next to the bulbs ;)
Cheers mate.
