Rocket Ron
VAG.COM input
Hi I have a Corado VR6 M Plate 1994 and want to find out whats wrong with my ABS as the light comes on. I know someone who has VAG.COM but don't know where to connect it into. Does anyone know where the diagnostic input is. What type of connector is it as i've read that there are two types.
Cheers
Hey
Your diagnostic plug is located below your gear lever surround.
gently lift the rear of the surround and it will pop up exposing the diagnostic plug.
Vr plug has a single big plug.
early valvers are the two small plugs i believe
Paul
I lift mine from the front - just watch the securing clips may rotate 90 degrees, no probs, just push 'em back. The VR may have 2 small plugs or one big one depending on age, not sure just when the change over was.
