robtalbott
bonnet release broke, please help!!
just been working on my new corrado today and the little metal clip between the bonnet release handle and the cable snapped (see pic)
can't open the bloody bonnet or anything. tried holding the cable sleeve and pulling on the cable with pliers but it's far too stiff
any suggestions?
is it not the case though that that thread is for snapped leads? my lead is fine its the small copper(?) plate that links the handle and the cable together that's snapped
These threads tend to cover most bases rather than just a specific problem. Still, the advice remains, have a look through the search....
Advanced Search:
+bonnet +cable
Normally I'd suggest restricting to one forum but for this it would be worth looking in Interior, Exterior and also for the people that don't realise the bonnet isn't actually part of the engine, Engine forum.
Return Topics rather than posts.
20p says that resolves your question :)
just in case you've not managed to have any luck the way to open it is this:
using two pliers, hold the cable in one and with teh other pliers, close them so you can see that oval centre section. Put this against the cable sheath, dont HOLD the sheath with it, your objective is simply to provide a resistance to the next step. Now pull the cable and simultaneously push the sheath in the opposite direction ie you feel as though you are trying to pull the cable out of the sheath. Its important to push teh sheath as this pushes the driver's side bonnet release arm. Its an unnecessarily complex setup, but i guess Karmann had their reasons :shrug: Good luck, you'll sort it out, its really not too difficult, perhaps a little fiddly.
