Gaz154
Earth Strap
anyone know the location of the earth strap points on the gear box and engine on a 93 vr6 engine and how easy it is to change it over suspect mine is goosed
There's some earths under the upper plastic cowling (above throttle body) and there's also one on the gearbox that terminates to chassis leg under the battery.
If I were you, repair that earth and then run an extra earth strap from the battery to the back of the head. This just acts as a fail-over in case the main earth fails, which it sometimes does due to that green copper corrosion.
K
