Flexso 0 Posted September 30, 2009 Hello All, Just wondering how I remove this without breaking it? Is it held on with bolts? Thanks Quote Share this post Link to post Share on other sites
Flexso 0 Posted September 30, 2009 can anyone help with this one as i was going to try and take it off tonight. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted September 30, 2009 there are single use clips on the back mate. not the best design in the world. Best bet is to source a new one or be as gentle as possible when removing it so not to break any of the little 'pegs' on the back of it. Then use these to fashion your own way to fix it back on. May not seem clear but you will see what i mean when you have a look :) Quote Share this post Link to post Share on other sites
Flexso 0 Posted September 30, 2009 there are single use clips on the back mate. not the best design in the world. Best bet is to source a new one or be as gentle as possible when removing it so not to break any of the little 'pegs' on the back of it. Then use these to fashion your own way to fix it back on. May not seem clear but you will see what i mean when you have a look :) Thanks for the heads up. :D Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 30, 2009 just taken mine off once you have removed plugs or screws you can gently pull it towards you then get a screwdriver and scrape away at the sticky stuff at the bottom it will slowly release itself as you are pulling it 8) Quote Share this post Link to post Share on other sites
