ken corrado 0 Posted October 11, 2009 will a h reg loom be the same as a l reg? how hard is it to get the dashboard out? Quote Share this post Link to post Share on other sites
Toad 0 Posted October 11, 2009 Which wiring loom? Dash? Engine? Quote Share this post Link to post Share on other sites
dragon green 4 Posted October 11, 2009 L reg will be a later loom if your talking about the dash dash removal about 3 hours,this should help- viewtopic.php?f=45&t=83262 Quote Share this post Link to post Share on other sites
ken corrado 0 Posted October 11, 2009 dash loom has melted, i got some cheap fuses that didn't work i dont no how much damage has been caused but there was a lot of smoke from behind the dash and from what i can see there is a lot of meltid wires behind the light switch. Quote Share this post Link to post Share on other sites
dragon green 4 Posted October 11, 2009 When my light switch went wrong,that caused a mini fire ! took a lot of time to sort out all the issues it caused ! the light switches are very well known on here,most likeley that ,then your cheap fuses Quote Share this post Link to post Share on other sites
shaung60 0 Posted October 11, 2009 Your H reg is an early car and the L reg is a late car. Looms will be different. Changeover year was '92. Headlight switch has it's own loom. ABS (if fitted) has its own loom. Fogs & HRW share the same loom. Clocks have their own loom. I think they are different between analouge and digital clocks. All can be replaced easily enough without having to take the dash out. Chances are it's just the headlight loom that's gone. Caused by your headlight switch and cheaps fuses not liking each other. Quote Share this post Link to post Share on other sites
