G60Dan
Tyre pressure for 205/40/17's
You need high pressures I would imagine, cos if the tyre is very slightly soft kerbs and potholes will go straight through the tyre and hit the rim... You need more sidewall if you don't want a hard ride...
30/32 or 31 is what i normally run depending on what the weather is like in the inwter i do tend to run around 28/29 so it grips the road a bit better
2p's worth
