dom911
how to remove the ecu
as above need to remove the ecu whats the best way to do this,have had a look but can't see how to get it out,don't want to brake anything so any help would be great.
need to move the scuttle cover back on the left hand side
then that reveals a 10mm nut which you need to undo then disconnect the wiring loom
then push the ecu towards the fan air intake to unclip it from the rest of the retaining clips then wiggle out its very tight (oohh er missus) :D
hope this helps
hope this helps
Thanks will have ago 2mora.
