miles_davey 0 Posted October 17, 2009 When in low revs and I give it some beans the engine is over reving and the power is not coming through. It's something similar to what you would expect if you had the clutch down slightly but I am sure its not this?? As a point of interest I recently had the head casket done and this is pretty much when this problem started so i wonder whetehr the two might be associated? Any help you can provide would be much appreicated. thanks Miles Quote Share this post Link to post Share on other sites
miles_davey 0 Posted October 17, 2009 everthing i read sugests it's the clutch (although not totally convinced) so i am going to go with this - any idea of costs, decent garage in bournemouth area? Quote Share this post Link to post Share on other sites
Reggit 0 Posted October 17, 2009 To test clutch, try and set off in 1st gear with the handbrake on. If the engine stalls then the clutch is ok, if it doesn't the clutch is goosed. Don't try it for too long, or the clutch will be knackered. Quote Share this post Link to post Share on other sites
Swompy 0 Posted October 17, 2009 miles_davey said: When in low revs and I give it some beans the engine is over reving and the power is not coming through. Ummm maybe you should try petrol insted of beans, Might help a bit :brickwall: :lol: :lol: sorry I couldnt resist. I will get my coat now and let you solve the probolem :wave: :grin: Quote Share this post Link to post Share on other sites
Conker 0 Posted October 17, 2009 Swompy said: Ummm maybe you should try petrol insted of beans, Might help a bit :brickwall: :lol: I exclusively use Shell opti-heinz beans - the power delivery is definitely smoother!!! Quote Share this post Link to post Share on other sites
Timbo 0 Posted October 17, 2009 ...but a bit stinky? Quote Share this post Link to post Share on other sites
miles_davey 0 Posted October 19, 2009 apparently I've been reliably informed its because i used basics. Quote Share this post Link to post Share on other sites
