Novastrike 0 Posted October 19, 2009 Hi guys, Whats the difference between early and late interiors specifically the seats. I would like to change my pretty good condition cloth interior for a tanned leather interior and wondering if i should stick with late (which is the same as my car) or consider earlys as well. Thanks JP Quote Share this post Link to post Share on other sites
KADVR6 0 Posted October 19, 2009 seats are the same mate, its just the doorcards that are different. Quote Share this post Link to post Share on other sites
ryan_16v 0 Posted October 19, 2009 seats are the same mate, its just the doorcards that are different. Not quite true, the pin fixing to the rear seats are slightly differant. The early type the pin is small diamiter as oposed to the late being larger diamiter, i had to drill a bigger hole in my car to accomadate a later spec interior. Quote Share this post Link to post Share on other sites
Novastrike 0 Posted October 19, 2009 Sorry for being a complete corrado novice!! Is there a big difference in the door cards. Would it be difficult to change/modify the pins so that early seats would fit into a late car? Thanks!! Quote Share this post Link to post Share on other sites
yacobwood 0 Posted October 19, 2009 for starters the leky window switch is in diff place Quote Share this post Link to post Share on other sites
VRDUBZAK 0 Posted October 21, 2009 late interior door pannels have differnet brackets to mount as well as differnt handles, and door pull's. you will need the mounting brackets from a late spec door to mount the different door cards as well as the window switches and the late door pockets. The pockets themselves house the window swithces as stated above. Quote Share this post Link to post Share on other sites
