michael.wilson15
Sunroof
A sunroof question for you guys. i know corrados have problems with these alot but the way mine works is confusing me the sunroof seems to have more of an electrical glitch you can open it all the way but it wont close or tilt with the button but this is not an issue when using the emergancy handle. is there a control relay or somthing for the sunroof.
Thanks
Michael
I believe your motor may be on its way out. If you have a spare motor, try that first, and also examine the wiring and switch for burns and bad connections while doing the swap. Good luck.
