warren 0 Posted October 22, 2009 hi is there any cleaning product that can enhance the look of my scratched drivers window?? a small bit of grit or something has got caught in the rubber and scratched the glass when opening and closing window :mad2: i was wondering if there is any way to get this removed without replacing the glass :confused4: Quote Share this post Link to post Share on other sites
big ben 10 Posted October 22, 2009 should machine polish out, not sure what polish would work best though, im sure most would depending on the depth... Quote Share this post Link to post Share on other sites
warren 0 Posted October 22, 2009 ive tried that with g3 compound but no luck!! i think it may need flatting of with a very very fine wet n dry then re polish with the mop ? Quote Share this post Link to post Share on other sites
big ben 10 Posted October 22, 2009 i would be tempted to try a 2000 grit wet sand and then use this polish http://www.cleanyourcar.co.uk/polishing ... d_215.html on a polish/cutting pad... or it probly would work out cheaper to buy one 2nd hand :lol: Quote Share this post Link to post Share on other sites
warren 0 Posted October 22, 2009 luckily i have a full variable speed polisher, so i will have to try again at it with the wet n dry, thanks for your help though matey :D Quote Share this post Link to post Share on other sites
big ben 10 Posted October 22, 2009 no worries, good luck, im sure you will get them out!! Quote Share this post Link to post Share on other sites
