jakegti
central locking not opening drivers door
the carhas a toad ai606 alarm fitted, the fob locks all the doors fine and unlocks everything except the drivers door. i have to put the key in the barrell and turn it so the central locking pump makes a noise and then i can open the drivers door. the airpump/mechanism at the bottom of the door locking pin feels abit loose and this makes unlocking and locking the door via the key feel abit slask aswell so could this be down to the problem or could it be the central locking pump?
thanks for any help
I would check the actuator in the door first ie the little pump that pushes the door pin up and also check the wiring in the drivers door jam.
Matt
