delfinis38
paintless care dent repair
apparently not on the Corrado as the steel is too thick. Havig said that, try it and see if it really is nonsense.
Indeed, that panel in the vid was flexing when he was wiping it clean.
Where do you buy liquid carbon though? I'd give it a go :D
Apparently you can buy it in Maplins,computer keyboard cleaner!!
Just make sure you use it upside down :)
I`m going to give it a try too,nothing to lose :)
Ive tried, using deep freeze pipe freezer from B&Q (same sort of stuff) and it did not work on my Ford Scorpio.
I think one of the other clips on there describes it better "it only works if it's not creased". To get a dent like that on a Corrado takes quite a bashing as its quite a thick body and it causes to much damage to just pop out.
