dgtvr6
Yes, I am stupid
All
yes, I am stupid and will now prove this by asking todays most stupid question....
I have a momo with boss for a Corrado... is it straght unbolt old and bolt on new steering wheel or are there more steps/things to be aware of?
Thanks
just need to wire the horn. Easy. You will see how it work. Also make sure you bend the metal strip on the back of the boss down slightly so it makes a connection. You will see what I mean when your doing it.
Cheers!
Off down to try it in a few minutes then
All
Thanks
You should have PM'd or text me and I would have let you know.
I'm glas it arrived down ok and Its a piecs of piss to fit.
1- pop the front cover/horn off the wheel you have in your car.
2 - undo the spade connection from the horn.
3- unbolt the large bolt in the middle.
4 - using the same bolt, bolt the boss in
5 - use the 6 hex screws to bolt the wheel to the boss.
6 - push the speade connector onto the horn push and use the 3 screws to bolt the cover/horn push to the wheel.these 3 need to be screwed from the back :censored:
easy peasy
All
Thanks
easy peasy
No offence intended... Simple enough to ask all..
Fitted now and looks very nice indeed! Thanks
