iMation
few things :(
is the knocking noise like a clak clak rattle noise?
Could be Detonation.
Loose seal on the exhuast manifold tends to produce a sort of ticking noise.
erm i would say a ticking noise more than a metalic noise
it gets faster obviously the faster i go through the revs, then change of gear and it starts again.
Detonation is possible due to a wobbly crank pully?
Cheers for the suggestions peeps
Ok had the car on the ramps today,
cyl 4 Manifold was loose, as in very loose, the nuts were just about to fall of the bolts :S
So tightened up now and no more noise, also i replaced the Air filter today with a new K&N, also sounds better, old one must have been fecked!
Still gonna get the timing sorted just to make sure but...
THANKS to all the replys, has helped alot
Stu
Stu
laughing :clap: just make sure your K+N is the paper type not foam cause your charger wont like it
