turlock 0 Posted November 23, 2009 My steering's a bit iffy at the mo, can someone throw up a quick guide on how to bleed the system? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 23, 2009 undo the lowest point in the system (fill hose to pump?) and drain the old stuff out reconnect hose and fill from header tank, prime the pump by winding pulley around by hand (need to slacken drive belt) start car, preferably with tyres off the ground and turn lock to lock, filling the tank back up if it drains down and repeating lock to lock until the system stops making a horrible droning noise, that way all the air is out of the rack check for leaks :) you might want to unscrew the pressure hose from the pump and remove the pressure valve (keep the springs and bits in the order they come out) and inspect the little gauze filter inside for crud a second drain and fill may help to clean the rack out Quote Share this post Link to post Share on other sites
turlock 0 Posted November 23, 2009 Legend, thanks mate! :grin: How will the air get out while I'm spinning the pulley if I've closed the system back up? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 23, 2009 Legend, thanks mate! :grin: added a bit more info. Quote Share this post Link to post Share on other sites
turlock 0 Posted November 23, 2009 Legend, thanks mate! :grin: added a bit more info. So did I :lol: Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 23, 2009 Legend, thanks mate! :grin: How will the air get out while I'm spinning the pulley if I've closed the system back up? you want fluid in the pump for when the engine starts, you can add a bit of fluid till it runs out of the pump the other side if you like (you'd need the pressure hose disconencted then), but the bubbles in the rack will simply disperse up to the tank with the engine running and the rack turned lock to lock. TBH, when I did mine the fluid runs straight through the pump and didn't really need priming, but it's better to make sure it has some lubrication, most important on a brand new pump I guess. Quote Share this post Link to post Share on other sites
millerman 0 Posted November 23, 2009 i found that turning the steering (wheels of the ground engine not started ) primed the system really well as after the first time the pump was really noisy did it a second time and the noise went really quick Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 23, 2009 good point, going left/right without the engine running will gently push the fluid about in the rack and around the system I guess Quote Share this post Link to post Share on other sites
Toad 0 Posted November 23, 2009 I used a wire brush on a drill to spin the pump to get the fluid pumped round to start with. Quote Share this post Link to post Share on other sites
turlock 0 Posted November 24, 2009 Ok just thinking about this a bit more and went for a quick spin last night to get some sympthoms, basically the problem is that my steering feels a bit loose, best way to describe it is as if there's a bit of play in the wheels and they were moving slightly independant of each other. I'd be drifiting to the right slightly and as I gently correct it you'd almost feel it fall over to the left and then start drifting left. Terrible description but tough to call. I've read on here about bearings might be gone and also that the steering column should be replaced, any checks I could do to confirm? Seperately (i think) I also notice now and again I'd be turning a corner and the power steering would drop off and become heavy, this would happen very rarely and that's why I thought bleeding it might help. Seeing as it should really bleed itself I don't think this is the case, anything else I could check? Finally, I've recently put some 16" BBS wheels onto my C which is a G60, I used 5mm spacers all round, now both wheels on the right hand side of the car don't rub at all but when going hard right the back left seems to rub and when on a big lock (to the right) the front right rubs on the inside of the arch. I've been told the bushes could be gone causing this but I'm not sure that bushes could make any real difference to this, any general thoughts on this one? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 24, 2009 sounds to me like a combination of wobbly suspension top mounts, tired valves in the PAS rack and possibly track rods with play in the joints. have you had anything like wishbone bushes and bottom ball joints ever done on the car? Quote Share this post Link to post Share on other sites
turlock 0 Posted November 24, 2009 In one word, nope Could you put together a list of what I need to get, what you're saying sounds bang on and I want to try and get a sort of budget around work that I'm going to have to do. Really appreciate your help so far mate! So far my list looks as follows: Full polybush kit polybush Top mounts (front only or front and rear?) New power steering pump New track rods and ends Bottom ball joints (are these front only aswell?) Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 24, 2009 most of this stuff you can check for play on the car, although play is often most noticeable with the weight of the car on things and driving rather than just you levering for track rod inner joints (i.e. full new track rods) just hold the rod whilst someone rocks the steering on full lock (engine off), you'll hear and feel a clonk from the inner joint (where it screws into the rack) if it has bad play top mounts, you'll really need to remove the suspension leg to check play, but if they are really bad they partially collapse and flop about as you steer from lock to lock ball joints you can lever the appropriate bits with a tyre lever, that's all the MOT guys do wishbone bushes you can see breaking up front wheel bearings tend to make a horrid noise before they get play in them the steering colum play is usually felt with clonks on the column when turning and general paly in the height adjuster mechanism Quote Share this post Link to post Share on other sites
turlock 0 Posted November 24, 2009 Sound, I'll give it a go this weekend and let you know how I get on ) Do you reckon my list of replacement parts sounds good? (They're going to have to be done at some stage anyway...) Quote Share this post Link to post Share on other sites
turlock 0 Posted December 17, 2009 Just to polish this off, Left top mount was completely gone so the wheel was moving around a good bit, right mount wasn't that bad but changed it aswell. I'd changed the PAS belt recently and the problem with the power steering was that the belt had broken in a bit and stretched so just needed to be tightened, doh! :brickwall: Anyways cheers for the help lads! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 17, 2009 Cool - cheers for the update, if the top mount was as bad as you say the car must have almost been undriveable! Quote Share this post Link to post Share on other sites
turlock 0 Posted December 17, 2009 Cool - cheers for the update, if the top mount was as bad as you say the car must have almost been undriveable! Yeah it was getting that way so was only going very local with it, the bearings were gone on the problem one hence why I didn't notice dying over time Quote Share this post Link to post Share on other sites
